Bobby
turbo gt about to go fast
no i suggest you go to the tial 44mm waste gate i had a problem with the turbonetics one. but my problem was the opposite i had a 8psi spring and then it would creep to 12psi. i switched and it cleared right up. ps i also use the aem boost controller. also i meant earlier that you need to get vacuum from the intake mani to the boost solenoid then to the waste gate. get the bov from the mani too
