matt texass
- Joined
- Apr 10, 2007
- Posts
- 1,958
- Reaction score
- 4
Ya, running out of fuel needs to be addressed unless you want a pile of aluminum.
I think the manifold is ticking a little bit, but it wasn't like that when it was dynoed what if my clutch was slipping? Would it cause it to do that? Also when anyone else got a tune did your ABS light and brake light stay on?
the 6psi is prob from the exhaust leaksI started installing this kit on my car a while back and recently got it finished as well. Ok, well i'm not sure if you can call it "finished" or not, but it runs and drives. Its a pretty solid kit overall for the money, that's for sure. The only major problems I've had with everything are exhaust leaks that seem to constantly come back, no matter what you do to fix them, and oil leaks that do the same thing. It also has an 11 psi spring in the wastegate and it's only making 6, so I'm trying to get that figured out. It's slowly but surely coming along.
