Where does the sensor for the wide band go??
lostsoul
2014 vett or 2015 stang..
Gay Area
as SD would say, " Fuckiety fuck fuck fuck"
pulled out the sensor and let it hang in the wind like me.. turned on the W/B and held the button for 30-32 seconds.. closed everything up and went for a ride. while random driving it was from 23 to now I see lower numbers 12 and 13.. but when I was in 4th and went to WOT it stayed at 22.0! haha it did this a few times. I think Ill just wait till I get it fully tuned.. I think I'm running rich and I have not gaped the new ht0 and I'm pushing 13-14 psi. So much for plug and play... ahhhhhh
Alter Ego Trip
Pot Stirring Aficianado
White room with padded walls
That would make me very nervous. If that gauge is even close to accurate you're walking a fine line between a healthy motor and one with a rod out the side of the block. 14psi is way too much boost to be taking a chance on the wrong AFR.
On a side note. Even Innovative doesn't know how to tune their own gauge. The instructions that came with mine state to hold down the toggle for 3-4 seconds. Yet when I pulled the online PDF is states 30 seconds as you guys mention. Gotta love that.
lostsoul
Gay Area
well the tune that I'm running was only 470rwhp at 13-14 psi. I think he lowered the timing or something. The tuner also didnt change to the 4.10s and the cvmc deletes.. so I left his shop with a check engine light after paying tons of $$... nice. Anway, I'll try it again tomorrow. I read that you can do the fresh air cal if you do it in the morning when that car has been sitting for hours. Since I have no cats it should be pretty fresh in the morning.
lostsoul
Gay Area
Mother F@cker.. Went through the whole BS(again).. now when the car is warm at idle it will be at 19-20 which I think is fine.. but once again I lay into it and get 22. There is no knocking sound. I'm just going to have to wait. I cant believe its running that lean.. pos... f@ck f@ck..
And to add to that I was going to gap my plugs but cant find the gaping tool. Maybe if Don and some of his e-thug buddy's returned the first one I bought and mailed to share, I would have a spare.. ohhh dont think I forgot.. its been what 4 years now... no one sent it back to me... See what I get for being nice.. always get the big hard shaft.. ahhhhhhh I'm done.
james05gt
NJ
22 is wayy to lean at wot, I doubt your running that lean though. Might be a problem with the wideband O2 or the controller. I would return it to summit and get a refund. What was your afr when you got tuned?
lostsoul
Gay Area
its been a while but think it was 12 or something like that. The tuner put a real safe tune(the ass).. I had him build the engine and tune.. I thought if I get it all done at one place then I would be good.. well I had a 600+hp car running 470 to the wheels. That was a dumb assumption from me. I have the slowest 14psi mustang around.. even E-force stangs laugh at me.. I just cant get a break. =-/..
I sent summit a few tech questions.. it can take up to 3 days for a reply. As for returning it.. its a little late.. I bought it and didnt install it for a while now. If all else fails I have Ropers AED WB, but need to get the sensor from his car.
Alter Ego Trip
I'd agree. I don't have a tuner around who knows what he is doing to save his life. On one run my AFR was 15 to 1 :crazy:, my car was blowing black smoke like a mofo. At 20 to 1 I doubt it would make it through a 1/4 mile run at WOT.
