Saleen SC folks - new waterpump pulley?
Burke
South Florida
Hey fellas
bare with me here, as before the S197 came into my life, I knew nothing about working on my own cars :hammer:
Anyway, I just recently replaced the saleen plastic idler pulley with the stock oem metal one and changed my belt to the gates 108 - I am running the 3.6 pulley.
I saw this at Brenspeed
and remembered seeing (I think) some folks online talking about swapping out their waterpump pulley.... and wondered if this was what they did.
anyone here with a series VI running a different wp pulley wanna chime in, that would be great. Thanks!!
DAVE
Hawgman
THE fucking bad guy
Looks like the Ford V10 pulley in the pic to me.
sevenleaf
I run that pulley from brenspeed. It definatly makes the belt a little tighter. Didn't really notice much, for the price what the hell right?
tom281
Warp Rider
Dave I am putting on this pully next week...... PM me later I can tell you more about it.
gloryboy
S. Florida
Hey Dave......i've been running the v10 pulley for about a year now. The larger wp pulley causes the belt to wrap the sc pulley a little more. Helps prevent belt slip. With a 3.6 pulley you're prob fine with the stock wp pulley, but if you drop to a smaller sc pulley you may want to throw this on........
dly
Tom you don't need that pulley on a Vortech SC. They use those on Saleen's SC. :leghump:
MikeVistaBlue06
Inventor: Asshole Points
Richardson TX
Does this larger pulley reduce the volume of waterflow from the waterpump?
I would expect it to slow down the waterpump and that might cause issues in hot climates....
Just curious.
Mike
tmcolegr
It's All About the Build
Central, FL
Just curious.
Mike
Yes it does. However, the V10 W/P pulley still has a larger O/D than the Steeda underdrive W/P pulley. That combined with the OEM diameter C/S pulley yields a faster water pump RPM than the Steeda underdrive pulleys. No cooling system issues with the V10 W/P pulley.
tom281
Warp Rider
That's my understanding too. Hey tmcolegr, off topic but quick question- what psi are you seeing with the 3.0 pulley?
Burke
South Florida
GREAT - thanks for that bit of info, man
[and I found an old post of yours I had printed out a while back from Mod Fords where you talked about the belt/V10 pulley combo when you first put it on.]
tom281
Warp Rider
I was thinking of running a 3.2 pulley to see around 10, maybe 11psi. But if you're seeing 14 with the 3.0 then the 3.2 should be around 12 I would think.
tmcolegr
Central, FL
That can depend on some things:
air temps, air density, exhaust configuration, etc. With my wife's car which has a 3.2" pulley I'm seeing max boost of 11.8 psi.
2007 GT/CS
"Oderint Dum Metuant"
Columbus, OH
I've got 10 psi on a 3.4" pulley. I think you're right about the 3.2 (11.5 psi).
