You are finding out that ride is subjective. What someone thinks is fine, someone else might absolutely hate. I think you have a combination of too much spring rate for your taste and too little ride height. It might also be possible one or more of the shocks aren't up to snuff (that's one of the issues with D-specs not the best built things ever). That's an outside chance, but seeing as the shocks settings don't seem to matter I have to wonder if they are working properly.
well the shock setting does matter.. but regardless how stiff or soft i set it.. the car is still bouncing around like a moon buggy
i figured the best place to start is properly picked spring rates for street/track, cuz 225lb all around is certainly wrong.
once i figure out what rate to go with, i'll worry about dialing in the d-specs and other parameters..
don't you agree?
