Went to track now have a vibration
Jeffs FRC
Bartlett IL
So I went out last night to the track and on the third run when I hit 2nd car bit down and something didn't feel quite right...
The car now has a slight vibration at pretty much all speeds and there is a whining noise coming from the rear. Vibration is the worst around 45-55mph and the whine is loudest at around 70mph.
I jacked the car up this morning and ran it up to 20mph in first just to see if I could find a bent driveshaft or something. The shaft looked to be running true, but both rear wheels have a slight wobble. From just looking it appears to be about 1/8" back and forth on both sides.
Did I bend some axles and fuck the rear up?
Jeffs FRC
Bartlett IL
Just got back under the car to take another look at the driveshaft and it too has a wobble...
Jeffs FRC
Bartlett IL
Update!
Put the stock shaft back in and the car is fine.
I'll be giving Shafmasters a call on Monday to see what they'll do about this...
jgilbert04
Merrillville, IN
I have heard of others having problems with the Shaftmasters driveshafts also. I hear customer service is pretty good. Good Luck!
GrnBullitt08
Dale Jr
Northwest Indiana
He just said it was the driveshaft....
Sorry to hear about the driveshaft issues Jeff. Goodluck getting those worked out. How did the car do?
Jeffs FRC
Bartlett IL
I have heard nothing but good things about the 3.5". Like I said the car ran awesome before that 1-2 shift.
Track was very inconsistent and only got 3 runs in. Had to pedal it through 1st and 2nd... There is alot left in it for sure
60'-1.92
1/4-12.00
mph-120.7
GrnBullitt08
Dale Jr
Northwest Indiana
60'-1.92
1/4-12.00
mph-120.7
Oh yeah....there is alot left in it...a few guys around here run low 11s with that setup. Not bad for the first time out, especially with Matt out there running low-mid 13s lol.
Jeffs FRC
Bartlett IL
Matt was sissy footin it! He offered to let me take it for a pass, but I declined as I didn't feel comfortable beating on his car.
Maybe next time we'll swap cars...
GrnBullitt08
Dale Jr
Northwest Indiana
Not a bad idea.....He better get those times down soon. Or he is gonna be looking at my tailights too lol
Jeffs FRC
Bartlett IL
On a side note I shipped the shaft back to Shaftmasters today. Ill update when they get back to me.
Hopefully it can be fixed! $600 paper weights suck...LOL
EagleStroker
N/A Junkie
Memphis, TN
The thing is, the stock d/s may only be masking the true issue. The stock piece is designed to minimize vibration which is why most of us replace it. Something to think about!
Jeffs FRC
Bartlett IL
I thought about that too, but when I was directly under the car with it running around 20mph there was no question that the DS is slightly bent.
Also, the whining has disappeared...
Jeffs FRC
Bartlett IL
They don't warranty the driveshaft at all? You just bought that thing.
If its something that isn't a workmanship issue I doubt it.
There was a couple rub marks on the shaft, but nothing bad like some Ive seen pics of... Only one of the rub marks I could actually feel by running my fingernail across.
EagleStroker
N/A Junkie
Memphis, TN
If the suspension isn't loaded/moving down the road I think it would be hard to rule out everything. Whining will disappear just from the dampening from my experience. I had a similar issue about a year ago and it was caused from my OE UCA bushing basically coming apart.
Good luck working it all out! :beer:
Jeffs FRC
Bartlett IL
Thanks for the tip! I will definately check out the UCA. I checked the LCA's and panhard already and they are fine. Not sure why I didn't look at the UCA.
