Check Brake System
BlackKnight
Long Island, NY
I was driving today, and all of a sudden the "Check Brake System" warning came on. Check out the pics below... Why the hell would this of happend? They turned off about 10 minutes later. I was driving on a nice sunny day, so i dont think its weather related.
Anyone have this issue ever?
BlackKnight
Long Island, NY
Most likely a wheel sensor for the ABS, plug into the OBDII and it should tell you what it is..................
Where are the sensors located? I was poking around near the front suspension last night trying to troubleshoot something.
I will have to bring it to my fathers shop to get the computer on it.
mydangstang
Could also be a bad resevoir sensor (unplug it and see if the lights go out) Replacing the sensor is a mystery , factory replaces whole resevoir but as long as you're not loosing fluid unplug it because it's only job is to setoff warming lights.
AlloyGT
Lurker
Highlands Ranch
Reservoir sensor. Mine did this once in a while when it got hot, like sitting in traffic. Unplugged the sensor and cleaned the connector. All good after that.
mydangstang
You got lucky or I got unlucky because cleaning mine did no good. Mine works fine in the heat but not when temp drops.
