Whipple's New 10rib set up.
tommygodfrey
JPC Sales & Tech
Maryland
This set up is super nice and now available. I don't know if you guys have seen this set up yet but we have one here and will be doing the install if a week or 2 with a new engine on a customers ride. It's made by the supercharger manufactor and it's priced great. Check it out
Here's some more pics and details.
http://store.jpcracing.com/WHIPPLEs-05-10-Mustang-GT-10-Rib-Conversion-BLACK_p_749.html
SUHleen
Central Ohio
Wow, that looks like a nice setup. I'm sure someone else will ask so, what's the price point on something like this?
Liftedbronco
Shredder
Harrington Park, NJ
i was actually gonna say its free per the site...but then i gave choosing the color a shot and poof! ill take mine for free with no finish.
tommygodfrey
JPC Sales & Tech
Maryland
tommygodfrey
JPC Sales & Tech
Maryland
how beef is the tensioner because the steeda one is way hard lot of spring pressure
It's basically a factory 03-04 cobra style tensioner. But if you look at the design using whipples sliding idler that takes most the load and tensions the belt with maximum wrap which will not over load a spring loaded tensioner
Liberty911
FLA
How does this work in connection with the 8-rib conversions that replaced the PS, crank, WP and ribbed idler? Or do you have to revert back to the 6 rib system for those components.
Also, are there any clearance issues with the hood?
tommygodfrey
JPC Sales & Tech
Maryland
I works with the factory 6 rib set up. It's an upgrade over the 8 rib. You would have to switch back because off clearence. There are no hood modifications needed with this kit :thumb:
ryanralston07
Dalton, GA
I'm looking at running either 14 or 16psi whenever I build the motor. Do you think this kit will be necessary or can I run a better tensioner like the Thump RRR and/or an 8-rib setup to eliminate belt slippage?
