TheDarkPath
I did some searching and couldn't find much for this specific issue. I have a squeak in my rear suspension (sounds like primarily my driver's side) when going over bumps. It sounds like it's coming from where the spring meets the top isolator. The last time I pulled the spring out, I checked and didn't see anything noticibly wrong. I'm going to be pulling it back out this weekend to see about doing something to stop this once and for all.
Have any of you experienced this and if so, what can be done to stop it or at least lessen it? I have BMR lowering springs, tokico d-spec shocks set about half soft, BMR LCAs, BMR adjustable UCA, and BMR adjustable panhard rod. There are some days it doesn't make any noise at all and others it's so loud I can hear it both from inside and outside my car.
I have some similar squeaks in the front as well but I suspect the front strut mounts as I have the old style mounts which, as I've read, are prone to clunking and making noise.
