Help please
alexthejew
Jewish and lovin it.
ok. i was leaving hooters, and a gave it too much gas. over-steered, over corrected, went over a curb and into a ditch. i got pulled from the ditch. car would start, but barely ran. re-flashed ecu. car wont start. every thing else works. car cranks.
all help appreciated.
thanks
alex
alexthejew
ohhhh no i didnt. where is it? near the dead pedal?
alexthejew
i love being a part of an awesome forum. sorry ill go try that.
alexthejew
just to double check. im looking at the wiring diagram. the inertia fuel cutoff switch?
Gray Ghost GT
Road Racing Fanatic!
Madison, AL
Were the last words you said before the accident go something like this? "Hey girls, watch this!" :boobies: :thud:
Good luck with the repairs (ego and car). :beer:
GB10
8s coming soon?
Burleson, TX
Yes, inertia fuel cutoff switch. It's right by the driver left foot recessed in the kick panel.
Aandf1978
M90 SUPPORTER!!
Virginia Beach, VA
With you standing outside the car have someone turn the key to ON but do not start, do you hear the fuel pump kick on? If not start checking fuse #41 or 42 I think, one of those is the fuel pump fuse.
JEWC_Motorsports
S197 Junkie
Im wondering what else is damaged on his car. Pretty low to be fighting a curb and a ditch.
alexthejew
heres the update...
1. pushed the fuel cutoff switch and the car started.
2. i have a flat tire, but i have 4 new ones in my garage.
3. the power steering doesnt work at all
4. there is an exhaust leak
5. badly cracked front bumper
6. major scuffage on the tubular k member and oil pan. no leaks in oil pan, no bent a arms, no real damage apart from whats already noted. ill check again in the morning when there is light out. i already called out of work. gonna try and tighten down the headers in the am tomorrow and take pics for you all to see.
Ken04
gm troll basher
Santa Rosa Ca.
heres the update...
could have been worse, glad you at least got it figured out so you can get it back together. I'd be giving jewc75 some serious rep for diagnosing your problem.
lito
Caracas, Venezuela
Really sorry this happened but sometimes is the only way to learn, most of that have some years under the belt done that or worse.
Hope there is no structural damage on it.
why would you re-flash the PCM? afraid it got all shook up?
Maybe it suffered of amnesia.
