Query for those that installed "Chase" type Sequential tail lights...
Charlie Sheen
Armed and Hammered
Infernum ubi sum
When you ran the wire up to the battery, did you have to remove the battery to get to the grommet underneath it? Got any pics?
TIA
:rockband::piano:
GIG4FUN
Rock 'n' Roll Moderator
Iowa
+1 did both of mine that way. It was listed to do it that way in my directions....
Charlie Sheen
Armed and Hammered
Infernum ubi sum
Crap. I thought that you had to run a hot wire directly to the battery on the chase type lights. Thanks anyhow though :beer:
I'm just trying to finish up something that I started 6+ months ago :whistling:
don_w
Dyno Numbers - Who Cares?
San Diego, CA
I did mine in May 2005, I went to the battery. And yes, I removed the battery to feed the wire through.
MikeVistaBlue06
Inventor: Asshole Points
Richardson TX
I grabbed my hot connection off of the power connections for those Shaker 1000 amplifiers.
Seems to work just fine and I didn't have to run a mile of wire! :clap:
Hope this helps.
Mike
GIG4FUN
Iowa
Don !!!!! :samuri: We had this settled and you had to go and fuck it up! :tdown:
F00Mustang
Goes from a dig
New Orleans, La
I have amplifiers in my trunk allready with distribution blocks, so I just caught power there. BUT...
When I did the GT500 fuel pumps on a Whipple install for a buddy of mine (NOLAGT on the other forum), I did not have to remove the battery to feed the wire. I also did not have to remove it when I ran the power for my bottle heater at BAP through the same grommet.
I did have to remove the inner fender liner and then get a couple of new clips from Ford.
2007 GT/CS
"Oderint Dum Metuant"
Columbus, OH
My kit from Meter4it actually came with a spade nose connector that plugged into the passenger fuse block. You could probably get one at Radioshack or Autozone for 10 cents.
1Fast05Turbo
Flying Low
Valrico, FL
Roper's first attempt six months ago.
Charlie Sheen
Armed and Hammered
Infernum ubi sum
I hate wiring.
LOL. Actually, I was trying to figure out where the grommet behind the battery was located because I need to run a wire through there (and I wasn't near an S197). As luck would have it, Nick (S197GT) was at the Whipple factory yesterday and with his Redtop I got a good clear view at the back. However, thanks for all the help guys.
Herknav
Devil's Advocate
Arkansas
Add me to the "add-a-fuse" system in the passenger compartment...
Didn't meter-4-it add that writeup after someone on the other site did the add-a-fuse thing?
cekim
Large Member
Earth
"That car is afflicted"
"No, it just needs a little alignment hygiene"
Extra points if you can name the movie and actor (for the second line)....
Charlie Sheen
Armed and Hammered
Infernum ubi sum
"May I speak with his brother then? Mike? Mike Hunt?"
Crap, I found the webpage and the instructions aren't at all as I pictured. I apologize for my "Senior" moment, but after all, the "S." in Stanley S. Roper is for "Snotty". I pullled my battery, yanked the grommet out and saw the cabin filter staring right back at me. Dammit. Right turn Clyde.
cekim
Large Member
Earth
Ghostbusters?
Booo, hiss, NO.
"twy again, this time wif feewing"....
snotty Roper said:
I pullled my battery, yanked the grommet out and saw the cabin filter staring right back at me. Dammit. Right turn Clyde."
Are you still dorking around with that? C'mon man...
