A John In NJ
Rice Cooker
Im just gonna ask it here cuz I dunno where to ask.... Is it possible to get the stock 18" Polished Bullits wider? I think i heard of it somewhere im just not sure...I just want the 2 in the rear wider?
Did you ask em for pricing already?
Looks like I might be doing that then.. Cuz I love the bullits I just hate the fact that the rear are not wider...
Would an inch and half work or just an inch?
My 2 cents... decide on the tire you want first, and then widen the wheel to fit it. Almost all tire manufaturers websites will list the appropriate wheel width(s) for each tire. If you do it the other way around, you might find yourself in a situation where you can't use (or get) the tire you want. It may not matter in the end, but better safe than sorry.What tire size should I go with if I widen 2 in?
That depends on the width. If the overall diameter is say 29" or under, and the tire does not stick out past the fender lip, you should be OK.Could it be possible to run anything high than a 45 with a wide tire and still have clearance?
Also, can ask you a favor? If you call them, ask them what it would cost to narrow a 17x9 chrome bullitt wheel.
My 2 cents again... 27" is on the short side for a twin screw car on street tires (unless maybe the rear end is still 3.31... but even then I prefer 28"+).285/40/18
295/35/18
305/35/18
Are all decent choices. The 295/35 are closest to stock 27" diamater
