Make stock wheel wider?
A John In NJ
Rice Cooker
NJ
Im just gonna ask it here cuz I dunno where to ask.... Is it possible to get the stock 18" Polished Bullits wider? I think i heard of it somewhere im just not sure...I just want the 2 in the rear wider?
racevert
ZKiller
Illinois
Wheelcraft does it and they come out very nice. They can only add to the inside of the rim. You would probably need the wheel polished after they weld in the extra width.
KemahGT
James at WeldCraft quoted me $180 per wheel for up to 3 inches to the inside. This was for the stock 17" Bullits.
A John In NJ
Rice Cooker
NJ
Looks like I might be doing that then.. Cuz I love the bullits I just hate the fact that the rear are not wider...
Would an inch and half work or just an inch?
iirc - you could go + 2" on the 18s
A John In NJ
Rice Cooker
NJ
Nope, Just the rear.
Right now I have 255/40 18 on the rears that I could easily just replace the fronts with
A John In NJ
Rice Cooker
NJ
Could it be possible to run anything high than a 45 with a wide tire and still have clearance?
don_w
Dyno Numbers - Who Cares?
San Diego, CA
What tire size should I go with if I widen 2 in?
My 2 cents... decide on the tire you want first, and then widen the wheel to fit it. Almost all tire manufaturers websites will list the appropriate wheel width(s) for each tire. If you do it the other way around, you might find yourself in a situation where you can't use (or get) the tire you want. It may not matter in the end, but better safe than sorry.
Also, can ask you a favor? If you call them, ask them what it would cost to narrow a 17x9 chrome bullitt wheel.
285/40/18
295/35/18
305/35/18
Are all decent choices. The 295/35 are closest to stock 27" diamater
don_w
San Diego, CA
That depends on the width. If the overall diameter is say 29" or under, and the tire does not stick out past the fender lip, you should be OK.
A John In NJ
Rice Cooker
NJ
Gotcha and will do on the asking for a quote for narrowing
don_w
San Diego, CA
285/40/18
295/35/18
305/35/18
My 2 cents again... 27" is on the short side for a twin screw car on street tires (unless maybe the rear end is still 3.31... but even then I prefer 28"+).
a reasonable point.
John,
your gears are still stock iirc?
