Upper Control Arm & Pinion Angle Questions
copracer288
Lehigh Valley, PA
I'm looking at upgrading my Upper Control Arm.
With stock suspension, is it beneficial to have an adjustable UCA?
And, as far as pinion angles go, what is considered ideal and what is the factory angle?
COYO TT
Stangless
Annapolis MD
Im going to add to this question and ask if an adj. UCA is necessary for a standard 1-1.25" drop and the effects on pinion angle
S197 GT
PINK Casting Director
Nor Cal
The optimum angle will differ based on the application, but -3* would be a good starting point.
BMR Tech
Traction Vendor
Tampa, FL
Optimum Pinion angle, does indeed vary.
The main purpose of obtaining proper pinion angle, is to prevent binding within the drivetrain (driveshaft, joints)
The goal is to not have too much negative, or too much positive angle when the drivetrain is under load (when driving, or WOT)
Generally, -2* is a good setting if you have poly bushings. Up to -3* if you are still rocking the rubber stuff.
If you are running all solid ends on your rear suspension, -1* to 0* will usually be good.
Lowering the car will not majorly affect the pinion angle in a negative manner.
UCA is not a "must have", nor is it highly beneficial for stock suspension.
Wicked97
Beltsville, MD
:clap:
good post. I agree 100%
copracer288
Lehigh Valley, PA
Thanks for the info! What is the pinion angle normally from the factory and if I get a non-adjustable UCA, will I be in the ballpark with the angle?
Digital_Synapse
I was told with my Sportlines, that I need an adjustable UCA because I can break my DS. :helpme:
cshiznitzj
UCA with stiffer bushings will help negate the wheel hop. Lowering the car will bring the pinion angle closer to zero (theoretically possible to go positive if lowered enough). It is not difficult to change the UCA with a double adjustable, actually easy install. I set my UCA close as possible to the stock length UCA prior to install. After installed the pinion angle came out to -2 to -2.5 degrees (lowered on K-springs).
cshiznitzj
I measured the pinion and drive shaft angle relative to ground with two gravity angle finders. I had to remove one side of the exhaust to have a good line of sight to see the angle. Since it was so close to where I wanted it set, i left the length of the UCA alone.
tigerhonaker
TN
This I am interested in.
Thanks Vendors for your Post.
tigerhonaker
Liftedbronco
Shredder
Harrington Park, NJ
according to my link, there is a difference between what is desireable on a 1 piece (non CV) and stock CV driveshaft. At least i think stock is a cv
Rob72
No Japanese Mustang Here
Baltimore, Marxland
Why isn't the pinion set in relation to the driveshaft? This would minimize the driveshaft angles at the transmission and at the pinion. That's what trucks with a lift kit do because they have the greatest vertical distance between the trans and the rear.
