Busted my tail all for this....
justinS197
Go low or go home!!!
ATL Ga
Well it was a sucky,rainy and wet day just perfect for cleaning up and waxing! I still need some advice on the wheels and tires heres some pics at what i done!
BEFORE
1 notice the hood is just primed and ruff!!
AFTER
1 And now the hood looks painted and glossy but its still primer!!I also buffed the lights, and all thats needed is to be sanded a bit and clear coated!
5 I sanded the mirrors but heres the side i haven't done its real ruff and almost felt like velvet any ways heres before..
6 After I wet sanded it also ready for another clear coat!
7 Now tires and rims- whats the best thing to use to get this oxidation look off the rims? Im guessing some type of rim polish and a really good buff job?!?!
8
9
10
11 Im guessing that there is no way to fix these dry rot cracks that looks like tire stretch marks??
Heres what makes it worth it!!! 351 windsor!!!!!
Daniel Day
Resident psychopath
Newnan, GA
Justin, I somehow missed this thread. Good job on the hood, it came out great! :highfive: As far as the wheels go, you need to use a really strong wheel cleaner with acid in it. The acid will remove all the oxidation and rust. It will obviously remove all the polish as well, but that is not a problem because you need to polish them again anyhow. Now get some metal polish and get to work! Also, I have some extra screws for the center caps if you want them since yours are all rusted. With a little bit of time and elbow grease those wheels will look as good as new.
justinS197
ATL Ga
Thank ya sir!
Looks like a nice project ya got there. So what are all the plans for it?
Well it was goin to be a 347 but i decided i would rather build a 408 instead! I want to make an all motor build! Also i want to make this thing for some autocross events!! Im trying to get in good with a body shop so i can paint it myself!
Daniel Day
Resident psychopath
Newnan, GA
I know I already told ya, but that thing is not going to be very ideal for auto-x. It is going to be really nose heavy with that 351 block up front.
keeno
Mustang Freak
Atlanta, GA
You need a power ball for your drill and some Mothers Mag and Aluminum polish for those wheels...way less elbow grease!
