Offset comparison
matt texass
I really like Enkei Lusso wheels http://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&autoMake=Ford&autoModel=Mustang+GT+Coupe&autoYear=2006&autoModClar=&initialPartNumber=4698806540BML&i1_Qty=2&wheelMake=Enkei+Performance&wheelModel=Lusso&wheelFinish=Black+w%2FMach+Lip&showRear=yes&selectedRear=4698906540BML&i2_Qty=2 for the look and fact that they don't weigh a million pounds. However, I am concerned about the offset. They will be wrapped in 255 45 18 up front and 285 40 18 out back. I am on pro kit now (may be going lower in the rear) and possibly back to sportlines. Right now I am rolling around on stock 18 inch bullets and they are so far sucked in. I do not want that. How will these compare offset wise to the 18 inch bullets?
orangensaft
People think its yellow
Fairfield, CA
The 18 inch bullets are 8.5 inches wide with a +50 offset, so the 18x8 with a +40 offset will sit about .5 inch further out than the bullet and the 18x9 assuming it also has a +40 offset(your link doesn't say) will be about an inch further out than the bullets. Those are pretty conservative offsets and I doubt you'll have a problem with those tires and suspension choices. 18x9 replica wheels usually sit between 35 and 40. I'm planning 18x9.5 with around a +35 offset and 275/40s and that will be right at the edge of the fender.
orangensaft
Fairfield, CA
Yeah but it still gives you the basic measurements with different tire sizes, and various other fitment info.
908ssp
Michigan
Heres another one that lets you input different tire sizes too.
http://www.rimsntires.com/specs.jsp
Now that is a cool web calculator. :highfive:
Remember with any calculator the actual size will vary. Not a huge amount but some. I measured my 315/35s on an 11" wheel which according to Nitto was the size they used and it measure between 308mm and 312mm not 315mm. Not a big deal but worth noting.
