What did YOU just order? (Reading Comprehension Test)
GrnBullitt08
Dale Jr
Northwest Indiana
My Porter Cable, bottles from U.S.Plastics (Thanks Nasty :beerchug2:) great prices, and the Auto Geek Detailers Bag.
Thats nice!!!!! :beer:
luillo
Fort Walton Beach, Florida
  • BMR Panhard Rod On-car Adjustable, Polyurethane Bushings
  • BMR Upper Panhard Rod Support
  • BMR Lower Control Arm Relocation Brackets
  • BMR Differential Bushing Kit
  • UPR Adjustable Upper Control Arm with Bracket Polyurethane Bushings
  • Steeda Billet Hardcore Anti-Roll Bar
  • JLT CAI
  • JLT Oil Catch Can
  • Raptor Shift Light
  • Stainless Works 3" Cat back System
  • American Racing Headers 1 3/4 Jet Hot and Off Road X
  • TA Diff Cover with load bolt
  • Tru Trak
  • FRPP 4.10
  • Strange Main Caps
  • SS Strange forged 31 Spline Axles
  • 9" Housing Ends
  • JPC Line Lock
  • Strange Rear 10 Way Adjustable shocks
  • Aluminum Drive Shaft
  • Boss Intake
  • Exedy Mach 700 Clutch Kit
I think that is all i just order :naughty1:
Zexford
Somers Point, NJ
Got everything together today, just missing a new bucket (gonna get one from Home Depot later). I actually used my new DA with the Ultimate Compound and the Ultimate Wax, I liked the Compound, got alot of the swirls and scratches out. The ultimate wax left a bit to be desired, not as easy to take off as everyone says. Its really difficult to see where you actually waxed because it dries clear really fast. Overall my first DA use was a success.
Here is a picture of after cleaning it up:
MUSTANG16
CAPE COD MA. - LAUDERDALE BY THE SEA, FL.
I have the bucket thingy … almost time to cut off the shrink wrap … YIPPIE!!!!
DKS
Wax on, Wax off.
VA/NC LINE
ZEX, with that grit guard you're probably going to have issues with a standard 5 gal bucket. It will sit too high in the bucket. If you check at Family Dollar or Dollar General you can find a short fat 5 Gal bucket that will work way better.
Also, WTF is that California Water Blade doing in that picture???????????
The car look sexy as hell though!!!
Zexford
Somers Point, NJ
It works well for me, never had any problems with it (ie. scratches)
Yeah, a bunch of guys were de-winterizing a boat they were giving me weird looks.
NastyStang113
Made in U.S.A.
Central Florida
What do you mean? There are some 5 gallon buckets that are slightly too tight but there's no reason why it won't work if you just push it to the bottom. If you push hard enough you'll be able to get it only an inch from the bottom. I'm guessing you're talking about this, right? Otherwise you can go with a set-up like this... :clap:
DKS
Wax on, Wax off.
VA/NC LINE
I believe he got his stuff from DI. The Grit Guards that they sell, which as far as I know, are the actual "Grit Guard" brand will not fit all the way down in a standard 5 gallon bucket like you would buy from Lowes or Wal-Mart. I've had several people complain about this same problem and I also have experienced this issue. Mine sit about half way up in a standard 5 gallon bucket. So, you have to fill the bucket all the way to the tippy top to use it.
Edit: And no matter how hard you push, they won't go down past about half way in a standard 5 gal. Trust me, I've tried. I love the short fat buckets I have, though. They fit perfect all the way to the bottom and fill the entire width of the bucket.
NastyStang113
Made in U.S.A.
Central Florida
It's not really a problem for me since I've got these buckets. However I used to use standard 5 gallon buckets from Home Depot with grit guards. I agree the buckets were too small for them to fit as intended but you can get them down but an inch or so off the bottom. It does push out the bucket where the grit guard sits but it gets the job done. Unless Florida gets special 5 gallon buckets. I've also seen people remove just a small amount of material from the grit guards and they end up fitting a lot better in the standard 5 gallon buckets.
Zexford
Somers Point, NJ
It is from Grit Guard, if it doesn't fit, I have a dremel and a steady hand, i'll just sand it down a bit to make it fit.
blk5.0
i just ordered some pre wow by black wow and some Optimum Metal Polish and Brinkmann Maxfire Dual Xenon Recharger. also got some meguiars clay bar kit going to have a full detail once i get my stuff
jcodestang
Mass
I just ordered more detailing supplies to do my friends yellow Boss F150, I needed some smaller pads to do the body kit. I'll do some before and after pics after i do it.
5'' D.A. Hook & Loop Flexible Backing Pl
foam Pad Conditioning Brush
3.5'' D.A. Hook & Loop Flexible Backing
4 Inch Hydro-Tech Foam Pad 3 Pack
White Lake Country 5 1/2 x 7/8 Inch B
BMWM3
Always Online
Cordova, Tn
a set of arp bolts for engine and heads. , going from 10.1 compression down to 9.2.1 compression and dropping the nitrous and adding a Twin screw. ...
