Comp Cams for Sale!!!!
shikwann
Madera, CA
I have up for sale a used
shikwann
pair of Comp Cams 127100S XFI VSR
shikwann
http://www.summitracing.com/parts/CCA-127100/
I removed them in preps to do a smog and finding out a follower broke. There are only fine scratches on bank 1 of the cylinder heads cam lobe. I do not believe that would affect performance at all.
I am selling because CA blows when it comes to emmissions and I have to remove these damn things and install the stock cams every so often to be able to smog in CA.
******* I also want to note that upon re-inspection I have found that one of the cam lobes has damage. I have taken the cam to the local machine shop and he told me that the lobe is indeed repairable. He said it should cost less than $100. I would check with YOUR local machine shop *******
These made GREAT power and drivability was just a tad worse than stock if not identical to stock drivability.
These only require a spring upgrade.
phaser limiters/lockouts are NOT necessary for these cams per Comp Cams.
$300 shipped.
DRock
Did you ever try to smog with them?
crazy88
Toronto, Canada
Man I wish these were NSR, the labour to get these installed would kill me.
Im sure they will quick though, cams dont last long around here!
shikwann
Madera, CA
If you have the right tools, like that freedom racing spring compressor then it shouldn't be too difficult. It should take a day to do if your'e somewhat mechanically inclined. Its best, from what I've read to upgrade the springs anyway for high rpm revin'
Dwisforme05
CF photography
Rome, GA
are there any videos to how these sound? i cant find one on youtube. what were the power gains?
shikwann
Madera, CA
I have a vid but I have my license plate flashing, so Im a little reluctant to upload it. Honestly its not too much of a difference. Id say there is a slight change in idle, but not much. It does sound slightly different when going through the gears when compared to stock cams. Its no where like hot rods, or thumper as far as sound goes. The cams have great low end too. I didn't feel any loss in low end, in fact I gained more below.
I didn't have it dynoed for a b4 and after. But honestly I've been driving around with stock cams and I don't have that extra pull that I had with the cams. Trust me you won't be disappointed, I wasn't.
Dwisforme05
CF photography
Rome, GA
just got it man, ill let you know shortly! i have a few things im trying to get rid of first!
