LMAO ! I have been reading the best wax thread.
I do have a question though, can you layer over a cleaner wax like the Zymol ?
I have some Blackfire Wet Diamond on the way as well as some Natty's Blue.
Layer as in what? Carnauba waxes don't really layer. They just kind've refresh one another. It's really a waste imo to put on more than two coats of a carnauba wax just to ensure even coverage. As a matter of fact the whole layer term is pure marketing bs by a certain sealant company in order to sell more product.
Any "cleaner" type product cannot layer itself, since it has mild cleaners/abrasives in it that removes anything below it. Glazes, Cleaner Waxes, AIO Sealants are all lumped into this category, and all should be used directly on clean clear coat/paint (i.e. meaning no other chemical products on the paint as the first application).
So if you wanted more pop to your coat of Cleaner Wax Zymol (believe it or not is rebranded turtle wax for the retail chain) then yes you could apply a Carnauba Wax on top of it (My recommendations in the $50-$100 category:
Pinnacle Souveran, Adam's Americana, Lusso Oro, Chemical Guys 50/50 (aka Wet Obsession), Dodo Juice Lineup, P21S 100%.
In the $100-$250 Category:
Zymol Concours, Swissvax Concorso, Zymol Carbon, Zymol Glasur, Chemical Guys E-zyme Natur, Dodo Juice Supernatural would be my top recommendations.
Personally, I would use a better pre-wax cleaner though as a base than the retail Zymol Cleaner wax though but that is just my opinion. Chemical Guys makes a nice bonding agent that does wonders for Carnauba waxes, as well as Zymol's Pre-wax cleaner, or Swissvax's Cleaner Fluid.
But since you are using a sealant, I would strip off your application of the zymol cleaner wax, since sealants like to bond to a fresh clean surface. So you can do a couple things. Get a spray bottle, mix it 50/50 with Isopropyl Alcohol, spray down the entire car like a detail spray and wipe it off. This will remove all of the wax, then apply your sealant. Wait a day for the sealant to cure, then apply your carnauba wax on top of it.
Sealant can never go over a wax, it won't bond properly.
