Here is my D1 and enclosed red race BOV on the dyno.
[SFIRE]2d890658-9911-4cb3-90ca-9e1b016e4ff8[/SFIRE]
I don't think he has heard of a BAP, plenty of people running just a BAP and the stock fuel system for up to 450rwhp+.
Depends on how much power you want to make.
What fuel pumps are you guys w/ stock motors running?
I posted on austin area stangs about how i'm about to put my procharger on and asked about good tuners in the area, and i got this response regarding the piggy back bap procharger supplies:
Yes, and unfortunately, you will not be ready to tune it, unless you add the gt500 fuel system-I have tested and documented the fuel systems deficiencies with the cut up procharger fuel pump install. The tune that comes with the prochargers shoots the commanded fuel pressure up 20+psi, because by 5000rpm, the fuel pressure actually drops 25+ psi. If you have not already done the gt500 fuel system, you will be on borrowed time, and getting a fubar tune to work around that problem, you'll still have problems. Ask me how many new 3v shortblocks I tune on a regular basis.
1. NEVER install gerotor fuel pump in a returnless fuel system.
2. Hacking up the fuel tubing on the sender further exacerbates the problem.
3. It just doesn't work.
4. Fuel pressure will have dropped 5-10psi, before you ever see it on a wideband sensor. About the time it is too late, and it goes downhill real fast.
Thoughts/opinions?
The GT500 fuel pumps are over kill IF YOU ARE planning on keeping it around 430. I made 450 on the HO kit as Procharger sends it with their canned tuned. Ran it that way for almost 2 years with no issues. BUT if you plan on growing I'd invest in the GT500 pumps and some 60lb injectors if you can afford it
Thoughts/opinions?
agreed.. gt500 is over kill.. 430 is low with these kits so just stick with what procharger gave you.. pop in base tune.. then go spend 40 bucks for a dyno run and make sure the a/f looks good and how much power you make..
If later you want more then get a bap, larger injectors and find the best tuner and squeez out a little more, but understand that a rod can go at anytime.
498whp on piggy backed fuel pumps and a BAP. While I dont like the piggy backed pumps, it holds up to 500whp just fine.
I plan on running the HO kit along with a dyno tune. F the procharger base tune. I have 39# injectors and colder plugs. With my bolt-ons i don't think 450 should be hard to reach. We'll find out in a couple of weeks
Good to know. You lost a motor right? Did you just put another stock one in? How much did that cost ya?
