Exhaust cutout locations
06GT-
Dallas
Cutouts
I am looking at running exhaust cutouts with turn downs right in this section?
Welding them in the last section right before it turns up over the axle
This 2006 has an 1.5 drop and a 285/40/18 rear tire
bambam 06
Cutouts
What are your thoughts, suggestions, recommendations?View attachment 117354
Mine are at the beginning of the bend, facing outward.
JC SSP
FL
Wow that undercarriage is super clean!
Cutouts are super cool! Would love to hear an audio clip (open/closed).
Midlife Crises
Fairbanks, Alaska
I’ve tried short exhaust a couple times. Once with 20” tubes bolted to the collectors, with and without straight through mufflers. And another time with bullet mufflers exiting in front of the rear tires. Both setups resulted in poor idle quality and reduced throttle response. Hesitation to accelerate and the popping and snapping were intolerable. Now I’m running 3” independent duals all the way to the back with oval chambers at the end. Much better sound with no stumble or lean pop.
