bunkered13
Car is an 08 gt with a turbo. Stock motor. Last night i was leaving work and the car seemed sluggish to start, like the starter was having to work alot harder then it should have too.
I figured the battery was going bad since its around 5 years old. Sure enough i had it tested and no bueno. Replaced the battery and still having problems.
If i can get the car to start, it will idle fine but if i push in the clutch to go in reverse, the car shakes real bad after the car starts moving. it acts like the car is only running on 4 cylinders.
The codes that show up on my handheld are:
P0022
P0012
P0340
P0344
I am really needing some help figuring this thing out. Thank you for any help in advance.
P0022
P0012
P0340
P0344
