Synyster06Gates
I have decided to just get a set of halogen replacements as it seems to flow better with my particular car.
Both lights are in good but not perfect condition. The driver side has typical wear from use - some small rock chips and minor scratches that could probably be polished out. The passenger side lens has a slight texture to it but only noticeable in direct sunlight. (EDIT : This is being fixed. I sent the headlight back to be replaced. The new light will be in good shape.) The previous owner tested bulbs/ballasts and claimed that they work - though I have not wired them up and tested myself. Driver side includes turn signal bulb as well - passenger side you'd re use your stock bulb.
Mounting tabs are in good shape - but the driver side looks very slightly different than the passenger side (maybe missing a small piece of plastic? but should work perfectly fine). Bottoms are perfect.
I placed an order for the wiring harness that makes these plug and play (expecting to install these myself) - but it will not ship out until next week. I can include this for an additional $50. It cost me $113 w/ shipping.
I am asking $650 shipped. $700 with wiring harness.
Driver side (notice how it's not a straight line on the right side of the V)
Pass side
Pass side
