W3bb3r04
Slow 3v Member
I considering going to 20" new style Roush wheels but the more I see 305/40 and 305/45 on 18's I REALLY want to keep the 18s
Would 19's be a compromise between "show" and "go"?
So many wheel size options.
what is tramline? never heard of it at all...
If i plan on doing bags. and 20.9 wheels. so i need to get the panhard bar still? These s197s are much more complicated than my 2004 mach i had lol..
I'm debating on the SVE drift wheels in 18 or 19. I know I will lose a little sidewall, but other than that I'm not sure what the downfalls would be. Nitto has some tires in 19 and they are fine with me. The weight is only 2-3lbs more a wheel. Any reason to get the 18s over the 19s that I am not thinking of?
Will my traction hurt that much from sacrificing that little bit of sidewall?
I love my 19" Drifts but, as others pointed out, tires are expensive so I'm going to drop back to 18's. Just trying to find an 18 I like.
The Nitto 555s are only 197.00 compared to 159.00 in 18s.
While not bad that's still $160 difference on 4.
so get the drifts in 18! That's what I'm doing...only thing is they are offset for sn95, but really not much more then your 19s...I love my 19" Drifts but, as others pointed out, tires are expensive so I'm going to drop back to 18's. Just trying to find an 18 I like.
I have an opportunity to score a set of 18" '10 GT500 rims for about $300-400 and I'm most likely gonna go for it.
I'm assuming they'll fit my Brembo car since the GT500 uses Brembos too.
As far as tires, I've been saying all along that I want 305's out back ... I don't know if 305's would fit on 9.5"-wide rims, so I'm most likely gonna go with 285/40/18's for the back ...
Anybody know if 305's would fit ?
305's would technically fit but they are definitely not ideal for a 9.5" rim. I think the 285 is as wide as I would go.
You will probably have a tiny bit of sidewall bulge with the 285's but you definitely can run them on the 9.5" rim.
