The car just died while driving. I initially suspected a broken fuel pump because it just stalled out.
The fuel pump pressure has been tested. The error code pointed to a throttle body issue. I replaced the throttle body, but the problem persists.
It was also suggested that a bad alternator could trigger that error code. The alternator was indeed faulty and has been replaced, but the problem remains.
I thought maybe the injectors are getting too much fuel, so I replaced the Fuel Rail Pressure Sensor (FRPS), but it didn't help. The fuel filter has also been replaced with no effect.
The PATS (theft light) is working normally: it illuminates for 3 seconds and then turns off.
Currently, the car isn't throwing any error codes. It starts, runs for 2–3 seconds, and then dies. After several start attempts, there's a strong smell of gasoline.
I'm honestly running out of ideas and I don't know where to look next. Does anyone have any suggestions on what else could be causing this? Any help would be greatly appreciated!
