2006 mustang v6 4.0L cel with code p0155
kain9090
Las Vegas
I am getting engine code p0155. It idles a little rough and has some trouble accelerating, but otherwise runs great. The car is stock. I have replaced the bank 2 sensor 1 twice with ntk o2 sensors. I have inspected the wiring harness and nothing looks damaged. I also confirmed it is getting the correct voltage. I did also confirm the short term fuel trim is within the right parameters for bank 2, not sure if that matters. The only other thing I could think of is a failing pcm. Any help would be much appreciated thank you
TexasBlownV8
Formerly TexasBlownV6
Central Texas
First of all, you need to understand the failure it is reporting for that sensor: heater circuit. There is 12 volts that feeds the sensor in a red/yellow striped wire, then the return voltage is measured by the pcm to verify operation, i.e. a proper voltage drop across the sensor heater circuit.
Exactly which sensor are you replacing, driver side or passenger side? band 2 is driver side. Sensor 1 is front sensor with green connector. For sensors, especially o2 sensor, I would only use ford/motorcraft sensors.
But before replacing, try swapping the 2 front sensors with each other, clear the code, and see if it changes banks. You'd be able to isolate a defective sensor that way.
If the code returns, the next step would be to check voltage at the PCM connector 175t (the smaller of the 3 pcm connectors), pin 24 red/lt.grn for bank 1, pin 25 violt/lt. green for bank 2. With key on power, they should both save similar voltages.
86GT351
Sunny South Florida
Very good explanation.
Gorje
California
What pins on the pcm connector are the ones for sensor 2 on both banks?
