2008 V6 Mustang Limp Mode
Jayp324
Ga
I purchased a 2008 Mustang from a friend replaced the engine with an 09 engine. I replaced the timing chain and tuned the engine up. The issue i have now is when a cruising at 60-70 mph after about 15 minutes the car goes into limp mode. P061C, i have changed the crank shaft sensor, the cam shaft sensor and the throttle body. Do I need to replace the PCM?
Jayp324
Ga
Yes,
The problems was happening before i changed the throttle body.
You should inspect all the wiring to those sensors for damage. A swapped engine can cause pinching or chafing of wires .
VGMStudios
Canada
I have a 06 GT. I replaced the engine with a 2009 gt. I added the TB from the 09 but my car did NOT like it. So I returned the 06 GT TB and the car ran fine. Something to try. Also make sure you connected the exhaust manifold sensors to the right side. I had mine swapped and car ran funny.
Jayp324
Ga
The code it gives me is P061c….Any advice to fix this?
GriffX
Rural Germany
Much better limp mode ;)
Have you tested the CPS wire? It should be high ohm against the engine housing (AFAIK). An other test could be a cooling spray at the ECU, when the car is in limp mode again, to see if it is heat related.
86GT351
Sunny South Florida
The P061C OBD error code in a Ford Mustang indicates that the Powertrain Control Module (PCM) has detected an issue with the engine's RPM monitoring system.
Possible causes
  • A faulty Crankshaft Position Sensor (CKP)
  • A faulty Camshaft Position Sensor (CMP)
  • A poor electrical connection at the CKP or CMP circuit
  • An open or shorted CKP or CMP harness
  • A malfunctioning PCM
Jayp324
Ga
Thanks, I took it to the shop to have the PCP checked. I changed the sensors. I didn’t see any wiring issues.
Jayp324
Ga
What is the best place to purchase a PCM from? The Ford dealership here says the part is no longer manufactured by ford.
Jayp324
Ga
Possible causes
Where is a good place to purchase a PCm
VGMStudios
Canada
Have you looked on ebay? Or maybe try car-part dot com. That's where I usually go for used parts.
