Limp mode problems
Demetre94
Long Beach, CA
Make sure you are monitoring the correct MAF parameter. You want 'MAF volts' change with rpm/throttle input, just to see if MAF working.
So the reading my scanner gives me for the MAF is g/s (grams per second). I truly don’t even know what that means.
Grams of Air per second. Which is the converted value of the raw MAF data. Maf volts is raw analog sensor data.
Demetre94
Long Beach, CA
I guess my question is, how do I properly diagnose the wire if it’s only throwing limp mode sometimes and not right after start.
Kev555
Ireland
I know there's a fuse in the engine bay fuse box that powers the MAF if you haven't checked it yet but I cant remember the number. check it out and if its making a good connection and not burned.
