viciousride
Needing more power!
Does anyone have a writeup on installing this kit? The FRPP website does not have instructions.
Thanks,
Mitch
Thanks,
Mitch
this is the only one I know of off hand
http://www.mustangforums.com/forum/2005-2011-mustangs/504117-gt500-fuel-pumps-diy-w-pictures.html
I just installed the kit on my 2010, use the directions for 05-09 Dual pumps and you will be fine. The only difference is in step 29C, 2010s have a 4 pin connector and the directions show a 2 pin connector. Take the Yellow/Violet and Green/Blue wire out of your stock 4 pin connector(plug that went into stock pump) and slide those into the 2 pin connector that is part of your new harness. Then run power to fuse distribution panel and you are set. If you cant find the directions on Fords site, PM me and I will forward you the PDF.
Good Luck
Anyone else see the irony of a link to that forum being posted on April Fools Day...this is the only one I know of off hand
It doesnt matter which wire goes into which pin, it measures ohms and no voltage passes.
BTW- I left the other 2 wires in the stock harness, I havent seen the electrical schematics but I dont know if them grounding or arcing could cause damage.
I hooked up the green/blue to green/blue and yellow/violet to blue/yellow. Sorry for the poor pics but Im at office and only have cheap camera phone to use.
Vicious what are you doing to require a dual fuel pump kit?
Edelbrock E-Force
A few pics of the install: http://www.viciousrides.com/blog/?p=107
Still waiting (back ordered) for the Competition CAI from Edelbrock.
Oh Shat! The cops are going to see my picture and know I'm in Germany![]()
