Hey guys, I have a 2011 5.0, auto, 18,000 miles, tune, axle back. Ever since I've owned it (and when it was stock too) I have noticed the idle is kinda crappy, warm and cold. Worse with a/c off, better with a/c on. Basically what I notice is a slight vibration every 20 seconds or so if you sitting in it, and if you are outside it you can hear a slight thump sound every 20 seconds or so. Idle rpm itself is pretty steady on my logs, tuner said logs all look good.
I did some research and it seems this is normal according to some forums? Do any of you have the same thing, and if so what is causing it? These 5.0's sure don't idle as smooth as my old 4.6's did...
Thanks.
Thanks.
