3/1/1 Engine Timing Cover
ct9989
SUFFOLK COUNTY, NY
I am running a gen 3 short block with gen 1 heads and gen 1 timing.
What timing cover should I use ?
Also, is there anything else that I need to consider for the build.
Thanks
ESP41
I’m running a 3-1-1 with an aluminator short block. I used my 1st gen timing cover.
Your 1st gen crank sensor will not work with a third gen backing plate. You either need to swap to a 1st gen backing plate or get the adaptor ring from Make it Modular
I used 1st gen head gaskets.
