Dark_horse
Im stuck on what to do tranny/clutch wise and really want to make the right choices. Im going to give out a couple scenarios and maybe you've got some educated ideas of your own. Motor will be making smoke very soon.
I probably know the right answer I just can't make up my mind...WHAT WOULD YOU DO??
I only get paid once a month and can swing about 1500 a month to put towards the car
Incase your not familiar with my build...
326 stroker (iron boss block) Built to handle 1000+whp, 10.5 compression with E85 in mind
big cnc ported heads with +1 intake valves manley springs and retainers
custom turbo grind cams
ON3 Turbo kit (70mm MP turbo)
Stock rearend, driveshaft, 3650 and clutch
405 pump with 39 injectors
Scenario 1... leave all stock driveline and only run 6-8 lbs so I can enjoy the car the rest of the summer since its been down all year. This will allow me to break the motor in and start saving up on the good stuff. most likely beefing up the rear end during this process since I will be in there for a gear swap anyways...I will have to purchase a clutch though due to the 8bolt crank right? If I do I will just find a cheap one that can handle 500whp/500tq as it will most likely not switch over to an upgraded tranny down the road.
Scenerio 2... Upgrade the input shaft to a 26 spline in the 3650, buy an RXT so it will switch over to the Magnum XL or 6060 later down the road...That would work right or is the Magnums input shaft a larger diameter?
Scenerio 3... leave the car on jack stands and not even fire the motor untill upgraded driveline is purchased no matter how long it takes me... would absolutely kill me to do this...
I will also be upgrading the fuel system to a return style system with E85 in mind to support some big power... So I also have that to throw in the scenarios as well.. ($2500)
And will also need to upgrade the turbo as well later...
Lots of shit running through my mind now that the motor is almost built and paid for....over 10k in this alone![omfg :omfg: :omfg:](/styles/default/xenforo/smilies/omfg.gif)
So I need some advice or just tell me what you would do... I cant make up my mind![thud :thud: :thud:](/styles/default/xenforo/smilies/thud.gif)
Thanks in advance....
