3650 to mt82 swap??? Anyone make it work?
Sinner
Plano, Tx
Has anyone figured this swap out yet? I've read that the speed sensor isn't compatible... 3650 is a 2 prong and mt82 is 3 prong.
stang8psi
Slower,Lower Delaware
I wouldn't waste the time or money for our garbage Chinese transmission my friend.. way better options out there to choose from
Sinner
Plano, Tx
Normally I would agree but for the price I'm getting the trans, clutch, shifter and drive shaft it's worth doing.
05gtowner
So. Cal
That would have to be free then. Anything over $500 bucks would be a waste.
Sinner
Plano, Tx
It's not a waste.... [emoji3]
Also, the way my car is set up the gearing in the MT might be the best choice.. I'll post up my chart I made in a min comparing the 3650, 6060 ('11 gt500) and MT82 ('14 gt)
gil_t2
Love Nitro in the Morning
Northern Va
It is a waste , with your procharger a 3.66 1st gear would be worthless unless your rear is 3.15 .
Jason09GT
Hewitt, Tx.
I think he's stated he is running a 28" rear tire. I love my mt82, I can shift it a whole lot better than my old 3650 on it's best day. None of the weird lockouts and crap people complain about. And, regardless of the gearing in the trans, and if it's going to be useless in 1st gear...isn't any supercharged mustang, regardless of the transmission...useless in 1st gear. I do most of my playing around from 2nd gear on up anyway. Start out in 2nd most of the time, or go 1-3-5-6 in town. Doesn't bog, or have a hard time taking it. I think it is geared perfectly..my 3.31's feel perfect, I wouldn't want 3.73's unless I ran a tall tire to offset it some.
I say go for it, you seem to always be able to be in rpm regardless of speed. Not like my old 3v, where you had to slow down, or speed up, to get it to a sweet spot where it would feel punchy.
Sinner
Plano, Tx
Gears
**** current first to second to horrible
Trans 3650 w/3.55
First 3.38 mph 0-45 (+0) rpm 0-6500
Second 2.00 mph 45-77 (+32) rpm 3900-6500
Third 1.32 mph 77-116 (+39) rpm 4300-6500
Forth 1.00 mph 116-153 (+37) rpm 4900-6500
Fifth .68 mph 153-225 (+72) rpm 4300-6500
**** first to second is just as bad as stock
Trans 6060 w/3.55
First 2.97 mph 0-51 rpm (+0) 0-6500
Second 1.78 mph 51-86 (+35) rpm 3800-6500
Third 1.30 mph 86-118 (+32) rpm 4700-6500
Forth 1.00 mph 118-153 (+35) rpm 5000-6500
Fifth .74 mph 153-207 (+54) rpm 4800-6500
Sixth .50
**** seems ok but a lot of shifting
Trans mt82 w/3.55
First 3.66 mph 0-42 (+0) rpm 0- 6500
Second 2.43 mph 42-63 (+21) rpm 4300-6500
Third 1.69 mph 63-90 (+28) rpm 4500-6500
Forth 1.32 mph 90-116 (+26) rpm 5100-6500
Fifth 1.00 mph 116-154 (+38) rpm 4900-6500
Sixth .65
Gears
Trans 3650 w/4.10
First 3.38 mph 0-39 (+0) rpm 0- 6500
Second 2.00 mph 39-66 (+27) rpm 3900-6500
Third 1.32 mph 66-100 (+34) rpm 4300-6500
Forth 1.00 mph 100-133 (+33) rpm 4900-6500
Fifth .68 mph 133-195 (+62) rpm 4400-6500
Trans 6060 w/4.10
First 2.97 mph 0-45 (+0) rpm 0- 6500
Second 1.78 mph 45-75 (+30) rpm 3900-6500
Third 1.30 mph 75-102 (+27) rpm 4800-6500
Forth 1.00 mph 102-133 (+31) rpm 5000-6500
Fifth .74 mph 133-180 (+47) rpm 4800-6500
Sixth .50
Trans mt82 w/3.31
First 3.66 mph 0-45 (+0) rpm 0-6500
Second 2.43 mph 45-68 (+23) rpm 4300-6500
Third 1.69 mph 68-98 (+30) rpm 4500-6500
Forth 1.32 mph 98-125 (+27) rpm 5100-6500
Fifth 1.00 mph 125-164 (+39) rpm 4900-6500
Sixth .65
Trans mt82 w/3.08
First 3.66 mph 0-48 (+0) rpm 0-6500
Second 2.43 mph 48-73 (+25) rpm 4300-6500
Third 1.69 mph 73-105 (+32) rpm 4500-6500
Forth 1.32 mph 105-134 (+29) rpm 5100-6500
Fifth 1.00 mph 134-177 (+43) rpm 4900-6500
Sixth .65
gil_t2
Northern Va
Second thought, it is not a waste, anything is better than a 3650, But for a street 90% track 10% car I really enjoy the two OD gears. My driving is in town or interstate no in between. You can always adjust gear or tires to get it right. I just love my 6060, and I changed the gears in it to , 2.99, 2.10, 1.45, 1.1, .74 and .50
Sinner
Plano, Tx
Has any one addressed the speed sensor issue?
I am running a 28.2 inch tire.
Sinner
Plano, Tx
I like the gearing in your trans.
