4-Shifter Bolts Spec
Demoic
Can anyone tell me what the tightness spec for the 4 bolts that go throw the base of the shifter are? Everyone says not to over tighten them and looking at the shop manual I cannot tell what they exactly call this to determine which spec it is.
Thanks in advance.
well than I have no idea what bolts you mean. good luck
irishpwr46
Official Site Vandal
NYC
about 4:40 they don't say to torque them to any specific setting but they do say they strip easy
irishpwr46
NYC
im sure if you snug it, youre not going to have to worry about torque specs. youre taking this a bit too seriously
nyuk98GT
Infrequent poster
Chesterfield, MO
Demoic,
You may not need help with this anymore since it is a few days old but I did a little testing today with my trusty inch-pound torque wrench and a small (1/2" hex head) bolt and nut. Result: 25 to 30 inch-pounds is about "wrist tight" for me (1/4" ratchet). I would not tighten the shifter plate bolts any more than 30 inch-pounds and, IMHO, 25 inch-pounds should be plenty. Use a criss-cross pattern (like tightening lug nuts) so that the plate is drawn down evenly.
HTH,
Chris
Falkinman
New Jersey
You could also try doing a search on the net for bolt torque specs. You will probably find a chart that shows a torque spec for bolts assorted by size and type but not specific to the application.
frank s
at Play
Paradise
Once you identify the size of the nt and of the bolt, it's not a long reach to the Old Mechanic's bit of wisdom: it's not arbitrary nor a coincidence that combination wrenches are the length they are. The amount of torque a regular-size, regular-strength person can apply with a given-size wrench is likely to be pretty close to the specifications for the nut/bolt as found in your chart.
lchauvin88
Marrero, LA
I would say no more than 10ft pounds if youre threading into steel. If into aluminum probably 5 would be sufficient. Use some copper or synthetic based never seize aswell. This will hopefully help from stripping the threads.
For reference. When I bolted the MGW on my t56 in my old car. I set the torque wrench to 10ft pounds. That was into aluminum and I used copper never seize.
30 inch pounds is roughly 2 and 1/2 ft pounds. My opinion thats not tight enough.
