420 cid SBF, complete, carb to oil pan
TexasKyle
D.I.L.L.I.G.A.F
Katy, Tx
Posting from another forum..
I do not know this guy, nor have I seen the engine.
Just posting in case someone here wants to take a look at it.
http://www.westsidemustangs.com/showthread.php?64499-420-ci-sbf-complete-carb-to-pan-new
picture.php
picture.php
picture.php
picture.php
TexasKyle
D.I.L.L.I.G.A.F
Katy, Tx
can not view it if we are not members it is telling me
Oops...here it is copy/pasted
420 ci sbf complete carb to pan new
Im thinking about parting out the coupe I have for sale. The first thing that will need to go is the motor. It is still in the car and you can hear it run. Im looking to sale it complete carb to oil pan for $7500 or best reasonable offer. It has at the most 10 min of run time. No times or numbers on it but it should make right arround 700hp n.a. Motor was built by Brian (STR)
You can reach me at 281-948-1280 or [email protected]
420cid Long Block
69 351w: 420 cid high nickel block, 4 bolt billet main caps, valley girdle pro system
Block was lined bored and honed, decked bored .040 and honed with torque plates. Coated Dura-bond cam bearings
Rotating assembly: SCAT 4340 forged crank and H-beam rods with .040 SRP forged flat top pistons. Clevite H-bearings and Total Seal rings. 0 balance assembly.
AFR 225 heads and Cometic gaskets. Scorpion racing roller rockers 1.6 with stud girdle.
Comp Cams approx .700 lift cam , solid roller lifters. 9 way double roller timing chain. TFS 8.6 push rods.
Melling oil pump and ARP shaft, Canton T-sump pan and pick up with baffles. SFI balancer.
Victor Glidden intake with dominator flange. Comes with adaptor for 4150 style carburetor.
MSD pro billet dizzy and wires.
Holley 4150 HP 850cfm polished carburetor.
NOS direct port kit mounted and plumed.
Fabricated valve covers
Electric water pump 35gph.
120amp alt and march bracket kit and billet pulleys
