I'm having no problems finding the Coyotes firing order, but cannot find out which cylinders are which number. I'm guessing 1-4 is passenger's side working from radiator towards the firewall, then 5-8 again from radiator to firewall but on the driver's side? Can someone confirm. I'm trying to diagnose a bad plug or coil-pack, and since the engine will give me the actual cylinder number of the mis-fire on my handheld tuner, I want to move the suspect coil-pack to see if the problem moves, if not, I'll do the same with the spark plug.
