95 lb Delphi injectors
1fast05
I wanna go fast
Gulfport Ms
These injectors are all flow matched at 85 lbs and require a injector driver and adaptors for the EV1 connectors, they're around 600.00 retail, All I want is 100.00 shipped
Genuine Delphi 96 lb/hour Low Impedance Injectors
These injectors flow 1000 cc/min at 43.5 PSI, These high flow injectors offer an excellent spray cone and very good response but should not be pushed to very high static rail pressures.
These injectors offer excellent response and atomization but should not be run at excessive rail pressures due to the disc design. Higher rail pressures with boosted / supercharged applications are acceptable with a pressure referenced fuel regulator because the pressure differential remains unchanged
