one eyed willy
Pizzle fo shizzle
Just got mine in the mail. Once programmed it will send out a ground signal that can be used to open or close a relay.
I have a few ideas on what i should do, not sure if anyone has messed with one of these yet?
1) I could cut power to my boost controller solenoid, but it would still run off the spring pressure of 9psi which may not be good.
2) install a relay inline with the oil pack power, to kill the coils,not fond of this but not sure of any other options
3) install a relay on one of the accessory feeds from the ignition switch that would cut the power like cutting the keyoff-probably best option
This thing looks pretty cool, it has a built in boost gauge that can also be datalogged, so i could remove my current 3bar map sensor if i wanted.
