Any home remedies for exhaust leaks
Goody05
Omaha NE
I'm haveing an odd exhaust leak on both sides of the Xpipe meeting the manifolds, I have them both as tight as possible. It is a pypes Xpipe it does have the slip in sleaves. Are there any home remedies that I can try to get rid of the leak?
007GTCS
Copper gasket sealer is what I am going to try. What year model?
Sent from Bat Cave.
007GTCS
05 and 06 shouldnt use the sleeves
Sent from Bat Cave.
Turd burglar
My bbr x pipe is leaking on my 13 at the drivers side ball and socket fitting. Rtv copper gasket didn't do shit, gonna have to get em welded.
Fullboogie
King of the Ski - OG Jr.
Houston
I recall posts discussing the need to replace the manifold studs to allow the midpipe to be pulled tighter to the manifold. A quick search should pull those up.
strictly180
im having the same issue with my 2012 and i also have the pypes setup its driving me nuts, i tighten them up within 2 or 3 hours thier lose already. ive called pypes and they said to use red locktite on the bolts, but i did that and it didnt work. my mechanic used the bolts provided with the pypes headers.
RazorbackMustang
MT82 Lover
Springdale, AR
I'm a douche and didn't read. I didn't catch that it was leaking at the manifolds. I continually have trouble with mine leaking at the next joint downstream.
