Anybody running dry sump?
Boomer_Gooner
I is a Texan
It might be a fat chance in asking, but I'm looking to see pics of an actual build with one and not the components like listed on Pascal Perf's website(Aviaid kit). Thanks in advance!
Kris_H
Chino Hills, CA
Interesting question, I'd be curious to see if anyone has as well. I confess I don't know all of the benefits of a dry sump system though. I know my E60 M5 is dry sump though. :)
Boomer_Gooner
I is a Texan
Prevents starvation in high lateral forces, better scavenging, cooler oil without the aid of a cooler, individual feed lines can be setup with different pressures in mind(eg piston squirters or valve spring spray bars) and the crankcase is in vacuum instead of pressurized so that you won't find yourself having blow-by issues(eliminates pcv valve). The best part is a lower center of gravity because you are able to lower the motor.
