philip_mustang
- Joined
- Jun 19, 2015
- Posts
- 96
- Reaction score
- 0
Racer47 is 100% right.
Philip - I don't know if it is a language barrier going on here or what but your tires are the normal 315mm Toyo R888 that a whole lot of people run on the backs of their Mustangs. The fact that an un-mounted, un-aired tire might measure slightly bigger than the stated width is not surprising at all. The 315 does not refer to the ACTUAL width, only the tread width, and manufacturers are free to make the tread as wide or narrow as they deem fit and still call it a 315. My 305 Michelins measure far wider than most 315 and fit fine.
I would recommend that you tell Paul that you plan on using the 315mm R888 and see what size/offset he recommends. A 20x11 with a 53 or 55mm offset is probably what he will recommend and I doubt that any modifications will need to be made at all.
There are people running big fat 325mm Michelins and even bigger with few, if any, problems.
Champale,
It def ain't a language barrier
The tire compagnie says they will narrow down with about 6mm in total when being inflated. The side walls of those tTyo's are really stiff so it won't mather that much.
When I measure the inside of the tire between the beads, from inside bead to inside bead is 270mm and from outside bead to outside bead it's 300mm.
Like Racer47 said, the plan was to go go for and offset of 60 to end right beside the fenders. But this will result in rubbing the inside.
The shop who's going to do the install the engine say they will never work. 305 no problem, 315 maybe, mine def nope.
Paul from Howey also says it's going to be a problem without adjustments.
I'm not intrested in tires who will barely rub or have only a few issues, I want none!
Those tires cost $460 each and if I mount them on the rims than I can't return them for sure. now it's still a "maybe"
The 20x11 rims are $475 each. So the total would be $1,870 for tmaybe taking the risk of encountering some problems.
It's like with the supercharger kit I bought and installed. Spent $14,000 on the kit, some other goodies, shipping and taxes for something that "normally" shouldn't be a problem.
The kit I have is within the general rule of thumb for good quality OEM rods.
Guess what? Just my luck that one of my rods seemed to be of a lesser quality. But again, normally the engines can take those kits, there are thousants of those installed in the US without any issues, just mine didn't.
And so I ended up spending almost another $20,000 for a fine engine, shipping, taxes, labour, ...
Maybe you would take the risk and order the rims because they "normally should work". But on other forums the most guys tell me not to do it.
I can be wrong but when I go for the 305's I have the certainty that they will work! And will that 10mm make such a big difference
