I had 4.56 gears installed about a month or so ago. Good install. Went to the track last night and lauched off of drag radials. The drive home was accompanied with decel rear end noise from 50 -65 mph.
This happened with the last set of gears I had too. One trip to the track with drs and decel noise.
I'm thinking the crush sleeve got crushed a little at the track. I'm planning on installing a solid pinion sleeve to cure this.
Has anyone else had this happen and if so did a solid sleeve fix it?
Thanks
Thanks
