BBR Short Block
ryanralston07
Dalton, GA
Is there a hp gain though since it will be able to rotate faster with less weight, or is it just a weight reduction?
EagleStroker
N/A Junkie
Memphis, TN
It makes for a more rev happy engine because of the reduced weight, its more responsive, if you were looking for hp don't waste your time to be honest.
Error404
photographer
Culver City, CA
I could be wrong, but I believe I read that aluminum (stock block) is about 80 pounds? and an Iron block is somewhere around 160 or so? I believe that's what I read. According to that link, the aluminum block is 130 pounds
one eyed willy
Pizzle fo shizzle
Lakeland FL
im using a stock crank on my new build,not planning on going above 600hp.
im not sure how much the stock block weighs,but with no crank i put it on my engine stand by myself with out straining, i dont think it was near 80# unless im just stronger than i thought,LOL.
my block is going out next week. im using a canton/MMR crank scraper(requires 2 oil pan gaskets). i still have to get a new rear seal and extra oil pan gasket to go with the crank scraper.im re-using my valve cover gaskets,manifold gaskets,oil pan gasket and timing chain gaskets.they are all made out of rubber and should be re-usable.
also bought the ARP main studs and 2v headstuds, for your info they are $150 cheaper than thee 3v head studs and still work just the same.
i got oem headgaskets from MMR for $140.
ryanralston07
Dalton, GA
How about a write up of the install? :thumb:
