Bent a piston rod
SilentScope
Chemist by profession
South Florida
They almost look photoshopped. Now imagine how big the machines are that MAKE those engines. Unbelievable.
Oh, and that Rod obviously bent because the ship had a fog light delete.
BMWM3
Always Online
Cordova, Tn
fuck the power and torque those things make think about the fuel needed for the combustion chamber. or imagine the size of the fuel pump. , or even the alternator
fdjizm
Drag Queen
NY/NJ
Is there a machine that can even bend that rod outside of the engine lol
NjsGT
Back in the game....
NJ
holy shit... wonder what the block looks like..... must be pretty cool...
mpf
Naperville, il
We USED to be the world's leader in those huge machines, right by me in LaGrange, ill. is the GM Electromotive plant, i think they only rebuild now.
I make chuck jaws for these guys, for holding pistons almost as big as our entire engine!
Once you start those giant motors, they never shut them off, even when changing oil. So a railroad motor will run for over 1 million miles, ideally, before it's shut down. Our forefathers had this art figured out decades ago!
captainN8
LaPorte, TX
Ship's Turbo!! It would take the whole Texas Mile to get that bitch spooling!! :lol:
This engine is out of the Emma-Maersk, a Container Ship. It's a two stroke Turbo Diesel that makes 109,000!! Horse Power and over 5 million torque!!!!
Look on the back side of the engine to get some idea of how big those turbo's are.
But that bent piston makes more sense when you realize how much torque is going through an engine of that size! Awesome picture of that bent rod!
Crazy! Engine from the Emma Maersk from Wiki.
Technical data (as of 2008)
engine configurationturbocharged two-stroke diesel straight engine,
6 to 14 cylinders
cylinder bore960 mm
piston stroke2500 mm
engine displacement1820 litres per cylinder
engine speed92–102
revolutions per minutetorque7,603,850 newton metres (5,608,310 ft·lbf) @ 102 rpm
mean effective pressure1.96 MPa @ full load, 1.37 MPa @ maximum efficiency (85% load)
mean piston speed8.5
metre per secondspecific fuel consumption171 g/(kW·h) (126 g/(bhp·h), approx. 3.80 litres per second) @ full load; 163 g/(kW·h) (120 g/(bhp·h)) @ maximum efficiency
powerup to 5720 kW per cylinder, 34320 to 80080;kW (46 680 to 108 920 bhp) altogetherpower density29.6 to 34.8 kW per tonne, 2300 tonnes for the 14 cylinder versionamount of fuel injected in a single cycle of single piston~160 g @ full load
