JUSTA3V
Moar Throttle!
I'm not 100 percent this was 3v tech so I stuck it here.
My issue is during a run I make 20 PSI but once I hit fourth and am nearing the top end of the track my boost starts bleeding from 20 down to 16 PSI. It does it every time.
From 6500 to 6700 I would say. Im 99 percent sure I have no leaks and am now wondering if its my valve overlap causing it? It seems too consistent to be belt slip at this point.
I don't feel the car lose any power as I cross the line. I only noticed the boost gauge dropping as I watched the video playback.
My slip shows the car is strong on the top end. Ignore the low ET vs MPH...I still cant get the car to 60'
I did 6 passes and the boost gauge does the same thing, around 6500 its starts falling to 16 PSI from 20 right before I lift at the end of a run.
Am I overthinking this? Is it more likely just a coupler is leaking under max boost?
Any suggestions are appreciated.
My cams are Comp 127200 NSR and my VCT is limited.
thanks,
thanks,
