DRock
- Joined
- Jun 22, 2009
- Posts
- 2,098
- Reaction score
- 4
I've been wondering how my Alloy GT would look with these:
These too could be hot. The last one needs to loose its white line though
and machine shop and always redrill a wheel for you. or you can run adapters.
FWIW bimmers are 5x100. i think lol im trying to remember what i had on my M3.
Well i called advant garde and they said that they can do either the audi fittment(if you want 20s) or 370z(if i want 19s) and they would machine it to the proper specs for my car however the only thing i would still need is spacers for the rears! I want the 20s bad cause 19s are a HUGE pain with tire sizes!
im thinkin bout buying rtrs and just have a shop wield about an 1.5 inch of rim on the rears so i can un a 325 or 315!
Wait why would you need to run spacers if they are going to machine the wheels down?
Damn it..you took my idea! haha I was thinking about buying them and getting them widened to 10.5" all around.
Either that or some HRE P40's
Those HREs are the sex. But you pay out the nose for them. I want to get my rears widened too, they are 20x10 right now and would like a 20x11 or 11.5.
But arent RTR"S still 19's?
And Audi specs would still be the wrong lug pattern im pretty sure.
uhm...Audi's have a different bolt pattern and center bore so they wont fit, and even if you do manage to bolt them on some how, the offset would probably not work either.
No machining in the world or spacer will make those 19's for the 370z fit on the S197.
IIRC there was someone on another Forum trying to get a batch of those wheel made in the correct bolt pattern and offset but couldn't get enough interest to get them made.
The guy from advant said that depending on the size that i want i would have to go with an audi wheel and have it machined to my specs(114.3 bolt pattern and a 70. somthin bore) i dunno how they would do that since, like yall mentioned, its a completly different bolt pattern!? the 370z fittment would actually fit(since the hub bore is like 66ish) but with the offset being 35mm you would have to run a spacers on the rears!
I would say screw it and get HREs but im not willing to drop tht much just yet!
Hear me now, believe me later... 35mm offset on a 10 or even 10.5... spacers are not your answer.
Advant Garde wheels
I'm guessing they are talking about doing a fill and re-drill on the Audi wheels, but they still would fit because the offset is all wrong. You'll have the same issues as the 370 wheels.
Like I said the 370Z wheels are not going to fit either.
For example:
35mm+20mm spacer does not equate 55mm.
For every mm you add to the original offset you're taking away.
35mm-20mm=15
70mm-20mm=50
So basically a 35mm offset is already pass the fender on a 11" wheel adding a spacer will only be pushing the wheel even more pass that point of where you started.
x3
The LOWER the numerical offset, the MORE your wheels will stick out, a spacer with only LOWER your numerical offset.
im gonna have to "X2" what Peetie is saying.
Back to the linea's that we were talking about - theres quite a few they make that i like. they actually make replicas of those RTR wheels too. Theyre plenty concave. And have additional finished you cant get from ford (ie. smoked chrome).
Thinking about picking these up in 19x9.5 having them shave the hubs to a 30mm offset and widening the rear wheels to 11"...seems like alot of work just to have P40 reps fit though haha
