boost-a-pump ?????
5.SLOW
missouri
I have a vortech boost a pump for 11-12 mustang gt. just curious if I could wire that up to my 07 gt?
I don't see why not. If its a plug and play version it likely wont be plug and play though.
travelers
Eastern Pa
I think I would contact Vortech to make sure. I'm not sure the '07 FPDM is the same as the later '11 are.
No concern there, fpdm (05-10) vice fpcm(11+) they still do the same basic thing, all your doing is boosting the voltage in so it has more to send to the pump.
Edit off vortech website.
"Specifically designed for use on 2011-2012 Mustang GT, but can also be used as a universal assembly"
http://www.vortechsuperchargers.com/page.php?id=30184
There is a wiring diagram in the install pdf, only difference would be its a white wire for the inertia wire on a 05-09 vice purple/green.
http://www.vortechsuperchargers.com/images/63.pdf
