Boost a Spark instruction
Limetime
I need to install a Kenne Bell Boost a Spark does anyone have the instruction?
i have been looking for a write up but can't locate one!!
Please and thank u
Limetime
U can't read it
i printed and tried to clean up the page but still nothing
Limetime
TRying to figure out ( in and OUt of the BAS box
2005-2006 Mustang GT boost a spark
http://www.kennebell.net/accessories/boostaspark/boostaspark.htm
I have direction i found online but can't see a fucking this, but there is a write up. I just don't understand it Trying to figure out what end goes where? lol
If i cut the 2 red wires and have 3inches left Where should those 2 (3inch ) wires go ??? To the Fused IN side of the BAS box or the non FUSED OUT side location?
This is pretty much the only thing i have found online
That is a pretty straight forward schematic. The BAS is installed BETWEEN the 12V power to the coils and the coil packs. That is what that wire C5 is. You splice it in there as shown on that schematic.
The red "IN" wire is fed from the stock coil power relay. You then tie the red "OUT" wire to the connector so the power goes where it was supposed to go, just boosted a bit. The ground is, well, the ground. Get a good, clean ground. Other than that, you have to install the controller and then wire up the boost switch so it knows when the boost is coming on and it can increase the voltage to the coils primaries.
I'm scared to death of ELECT shit since the last car fire lol
please help i am retard
http://www.svtperformance.com/forums/sn95-cobras-24/371205-kenne-bell-boost-spark-write-up.html
