Nickoli
I am installing a small wet shot on my 06 and my question is where should i put the fogger? normally i would put it about 8" from the throttle body but in my case i am going to also see boost there. Im not too concerened with the n2o pressure since it is 950 or so psi. but if i have 15psi of positive pressure on my intake tube (post turbo) will this effect the pressure the fuel coming out the fogger will see? If so i could re jet for a lower fuel pressure but how would i know what pressure to go for? I thought about spraying before the turbo so it will only see vacume on the nozzel but i am also woried about the fuel/n2o mix having to travel all the way threw the turbo, innercooler, and piping before it reaches the intake. that just seems like too many places that possible puddling could happen. anyone here spray a turbo car or even a cent. blower setup and if so what did you do?
