bought another motor....
Rangerclay
So, yesterday I was out looking for a tr3650 trans for my bullitt... I came across a junk yard in the Mobile Alabama area and they had a motor and trans for sale... over the phone they told me that it was a forged bottom end block yadda yadda, motor was in a 2010 roush that had caught fire while racig ( supposed fuel line broke or something like that). Anyways I went and checked it out yesterday and it was in fact a bottom end 3v.. mahle pistons, eagle rods and crank, arp everything... I ended up buying the motor and trans for 1400 cash shipped to my casa. I know absolutely nothing about the build on the motor other than it turns and has compression on all cylinders. what do you guys think about the buy? should I take the heads off so I can figure out what size head gasket they used? is there a mathematical calculation I can do from the cylinder compression to figure out what size gasket was used/ compression ratio, so I can get tuning correct? thanks in advance.
sman247
great buy in my opinion. I would def pull the heads off to get a better look especially considering you know the motor was raced. youve alrealdy saved a bunch of money on the build so spending the extra couple bucks will be worth it
RocketcarX
95% of my weight is fuel
Colorado
I wouldn't open it, it's doubtful the head gasket thickness will affect the compression ratio of an engine that was set up for a blower enough to worry about it causing tuning problems. You tuner will know how to monitor knock ;)
If it looks good under the valve covers and from below with the oil pan off why mess with success?
You could leave the trans bolted to it, set up a battery on the starter and do a compression test on the ground. Do a leak down at the same time, if that looks good install it.
Rangerclay
It’s on its way to the machine shop for a inspection, changing the head gaskets and porting the heads as well. Might as well while it’s there! I’ll update when it’s done and installed
